PROBLEM
When creating a map template in ArcGIS Field Maps Designer, a warning is returned: "This layer will not be converted into a template, and it will reference the original source"
First Published: March 17, 2026
Last Published: March 17, 2026
When creating a map template in ArcGIS Field Maps Designer, layers from multilayer feature services (services containing sublayers) are not converted into new hosted layers. Instead, the following warning appears:
This layer will not be converted into a template, and it will reference the original source.
As a result, the map template references the original feature service rather than generating a new hosted layer for each sublayer.
Additional Information:
  • The issue does not occur when using a single-layer hosted feature service created exclusively in ArcGIS Online.
  • The behavior is consistently reproducible with feature services containing sublayers, regardless of whether they were published from ArcGIS Pro or directly in ArcGIS Online.
Cause
This is a known limitation of the ArcGIS Field Maps Designer API. The tool does not currently support converting multilayer feature services (with sublayers) into new hosted layers when creating a map template.
Solution or Workaround
Publish each sublayer as an individual hosted feature layer before creating the map template.
Article ID: 000040589
Software:
  • ArcGIS Field Maps Designer
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
