PROBLEM
When adding a shapefile created from Pathfinder Office to ArcMap, there is no spatial reference information
When using a shapefile exported from Pathfinder Office, there is no spatial reference information associated with the file, even if a projection was defined in Pathfinder Office.
Cause
Pathfinder office does not associate a .prj file to the shapefile upon export.
Solution or Workaround
Define the projection of the shapefile in ArcMap to match the projection of the data in Pathfinder Office. This can be done with the Project (Data Management) geoprocessing tool.
Article ID:000008937
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
