PROBLEM
VRML export default navigation speed may be too slow or fast
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.When exporting to VRML, ArcScene does not set a speed property. Therefore, the default is used. This may be too fast or slow depending on the extent of data in the scene.
Cause
This is a known issue.
Solution or Workaround
Edit the output VRML file and add this:
Code:
NavigationInfo
speed 100.0
Adjust the number as necessary.
Article ID:000003735
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
