PROBLEM
Verify that your instance name and port number are correct in your services file. You do not have WRITE access to (path)
When using the Shapefile to Coverage tool in ArcToolBox, and clicking the OK button, the following error may occur:
"Verify that your instance name and port number are correct in your services file. You do not have WRITE access to <path>."
Cause
You do not have write permissions to the directory where the coverage is being saved.
Solution or Workaround
Verify that you have read/write permissions to the directory where the coverage is being saved.
Article ID:000005202
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
