PROBLEM
Validate did not discover topology errors
Validate of a Topology finishes quickly, and no topology errors are discovered where errors actually exist.
Cause
This can be due to issues such as:
- There is a feature in the Topology that contains a NULL subtype value. NULL subtypes are not supported by the Geodatabase.
- The data is in an ArcSDE Geodatabase, and one of the feature classes participating in the Topology is in load-only mode.
Solution or Workaround
Both issues can be resolved by installing ArcGIS Desktop 8.3 Service Pack 3.
  • At ArcGIS 8.3, features with NULL subtype values cause problems during Validate. With Service Pack 3 installed, Validate fails with an error message identifying the feature with a NULL subtype value.
  • Determine which feature class is in load-only mode and change it to Normal I/O mode. With Service Pack 3 installed, Validate fails and identifies which layer is in load-only mode.
Article ID:000006139
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
