PROBLEM
Using the f=json parameter in a service URL returns incomplete and unformatted JSON in ArcGIS Server
Last Published: April 26, 2024
In some cases, utilizing the f=json parameter in a service URL to search for an item or user in ArcGIS Portal Directory returns incomplete and unformatted JSON. In this example, typing the following URL to retrieve all the user information returns incomplete information, as shown below.
https://machine.domain.com/webadaptor/sharing/rest/community/users/<user>?f=json
The image of the incomplete details being returned after using the f=json parameter
The image below shows an example of the complete formatted JSON.
The image of the incomplete details being returned after using the f=pjson parameter
Cause
This is by design. Using the f=json parameter in the URL is part of a supported workflow that requires a token to view all data. The parameter without the token returns an incomplete JSON for security purposes.
Solution or Workaround
Use the f=pjson parameter
In the web browser, use the f=pjson parameter. In this example, the following URL displays the complete and formatted information.
https://machine.domain.com/webadaptor/sharing/rest/community/users/<user>?f=pjson
Acquire the token
In ArcGIS Server, acquire the token to access the complete JSON. Refer to ArcGIS Server: Acquire ArcGIS Server tokens for instructions. After acquiring the token, add the token after the f=json parameter in the URL.
This is the full URL with the acquired token:
https://machine.domain.com/webadaptor/sharing/rest/community/users/<user>?f=json&token=<acquired_token>
The image of the example URL with the acquired token.
Article ID: 000032518
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
