PROBLEM
Using SDO_FILTER to find points near the midpoint of a line in Oracle Spatial does not return rows
It is possible to identify and successfully perform spatial selections near vertices and end points of a long line stored using SDO_Geometry and a geographic coordinate system; however, identifying or selecting near the midpoint of the line or far from the vertices returns no selection.
Cause
The Oracle SDO_FILTER function used with SDO_Geometry data uses the geodetic model of great circle distances. The geodatabase searches and identifies using the Cartesian path.
The great circle path and the Cartesian path between two points are not exactly the same. This difference becomes evident on lines that cover great distances. The spatial location of the line in the great circle path can be different enough from the Cartesian path location of the line to prevent your spatial selection or identify from returning any information about the line.
Solution or Workaround
This is a known limit of using Oracle Spatial data with an ArcSDE geodatabase.
    Article ID:000008921
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
