PROBLEM
Using scripts to edit SDE annotation records causes annotation to disappear from view
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
Editing SDE annotation via graphics display causes annotation to disappear. The data itself is still in the table, but can not be re-displayed.
Cause
Editing an SDE annotation field by changing values in the text field results in corruption of the annotation graphic display.
Editing SDE annotation in this manner is not supported in any version of ArcView GIS.
Solution or Workaround
ArcInfo workstation can be used to make edits to the annotation.
Export the annotation layer to a coverage, edit the coverage, then re-import to post the changes made on the coverage to ArcSDE.
(this requires ArcPlot.)
Article ID:000005018
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
