Solution or Workaround
Problem
There are two Oracle instances, 'oracle1' and 'oracle2' and two ArcStorm databases, called 'asdb1' and 'asdb2'. When registering 'oracle1' tables to 'asdb1' and 'oracle2' tables to 'asdb2', and starting wservice, it can only register to 'oracle1' tables with either 'asdb1' and 'asdb2'.
Cause
The Oracle environmental variable ORACLE_SID has been explicitly set.
Solution
Do not set the Oracle environmental variable ORACLE_SID. Instead, specify the Oracle instance to be used in SETCONNECTINFO.
For example, if SQL*NET version 1 is being used,
SETCONNECTINFO oracle storm/storm@T:node:sidname
where 'sidname' is the Oracle instance.
Consult Oracle documentation for additional information regarding how to specify an Oracle instance during connections.
