PROBLEM
Using ESC to cancel TIN drawing has no effect if dataset has no breaklines
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.In ArcMap, when drawing a TIN layer that uses default symbology, if you press Esc to halt the drawing, you'll find the triangles stop but control is not returned to you for some time. This occurs for TINs that have no breaklines.
Cause
This is a known issue.
Solution or Workaround
Turn off the TIN layer's edge renderer from the Symbology tab of the layer Properties dialog box.
    Article ID:000003947
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
