PROBLEM
Using ArcPy to publish image services is no longer supported
First Published: April 22, 2021
Last Published: May 6, 2024
Any examples using ArcPy for image service publishing were written in Python 2.7. Even though they still work now in Python 3.6, they will not be supported going forward and may actually break with ArcObjects11.
Cause
The new Python 3.6 ArcPy method for publishing image services will not be implemented in the foreseeable future, although a function exists for map services. See: the help topic CreateSharingDraft.
Solution or Workaround
Esri recommends publishing image services programmatically only using JSON and the REST API for ArcGIS Server.
Article ID: 000025490
Software:
  • ArcGIS Pro
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
