PROBLEM
Code:
Function AVInitiate ()
On Error Resume Next '-- Set up error handler.
Dim chan, I, request As Variant '-- Declare variables.
chan = DDEInitiate("arcview", "System") '-- Establish ArcView link.
If Err Then '-- If error occurs, ArcView
Err = 0 '-- isn't running. Reset error
I = Shell("c:\av2\bin\troy C:\av-data\adesk.APR", 1) '-- and start
ArcView.
If Err Then
MsgBox "DDE connection error"
Exit Function
End If
chan = DDEInitiate("ArcView", "System") '-- Establish ArcView link.
End If
x = IssueRequests(chan) '-- Call function IssueRequests
If x <> 1 Then '-- IF the value sent back by Issue Request
x = reinitiate(chan) ' is not 1 then
End If '-- Call function reinitiate
x = Terminate(chan) '-- Call function terminate
End Function '-- END FUNCTION AVinitiate
Function IssueRequests (chan)
Dim request, answer As String, first As String
request = Forms![Customer Input]![TransferToAV] 'SET request = value from a
form
DDEExecute chan, "AV.run(""ADESK.Locate"",""" & request & """)"
'-- DDEExecute a ArcView/Avenue Script
'-- The first time this line will execute, but will exit function following
the
'-- DDEExecute, the DDE conversation is still active but Access fails.
'-- This happens the first run on start of Access and if Access sits idle for a
'-- extended period of time
IssueRequests = 1
'-- If this line is reached the DDEExecute did not bomb out, and the var
'-- IssueRequests is set equal to 1
countme = 0
checkone = 1
answer = "nil"
While (answer = "nil")
answer = DDERequest(chan, "AV.run(""ADESK.Zreturn"","" "")")
'-- This DDERequest looks to an ArcView Script which just returns a global
variable
'-- if the var is still nil the user hasn't completed a screen selection yet
and it
'-- will loop back through and request again
If Err Then
MsgBox "Caught in chkreturn error"
Exit Function
End If
'-- Checks if the loop has been running too long, if so times out
If countme > 5000 Then
MsgBox "Caught in chkreturn timeout error, try again"
'-- MsgBox "still caught " + answer
Exit Function
End If
countme = countme + 1
Wend
'-- This lines update a form in Access with the returned information
Forms![Customer Input]![DealerCustNo] = Left$(answer, 6)
Forms![Customer Input]![DealerFileCode] = Right$(answer, Len(answer) -
InStr(answer, " "))
End Function '-- END of IssueRequests
Function reinitiate (chan)
x = Terminate(chan) '-- If failed the first time close connection
MsgBox "Lost initial DDE connection, trying again"
'-- This Line is IMPORTANT!! Without a wait in Access
'-- The reconnection to ArcView will fail
'-- Seems the Access program and Windows System get
'-- out of sync.
again
If Err Then
Exit Function
End If
End If
answer = "nil"
'-- Following code is same as in IssueRequests
If Err Then
Exit Function
End If
If countme > 500 Then
Exit Function
End If
Wend
'-- MsgBox answer
InStr(answer, " "))
End Function '-- END function reinitiate
Function Terminate (chan)
DDETerminate chan '-- Terminate DDE link.
DDETerminateAll '-- Terminate all links.
End Function
Article ID:000001455
Get help from ArcGIS experts
Download the Esri Support App
