PROBLEM
URL parameters of the ArcGIS Survey123 form automatically change after being embedded into ArcGIS StoryMaps in Portal for ArcGIS
Last Published: July 19, 2024
When an ArcGIS Survey123 form is embedded into ArcGIS StoryMaps in Portal for ArcGIS, the survey's original URL parameters are automatically modified. As a result, the survey's header, footer, and theme are no longer visible in the story.
In this example, the URL below shows the original URL of the survey embedded in the story.
https://survey123.arcgis.com/share/9d80d1a717444499aae1e640c71e4ecd/portalUrl=<machine_name>/portal
The URL below shows the automatically modified URL of the survey after being embedded in the story.
https://survey123.arcgis.com/share/?open=web&embed=fullScreen&portalUrl=https%3A%2F<machine_name>.esri.com%2Fportal&id=9d80d1a717444499aae1e640c71e4ecd&hide=navbar,footer,theme
Cause
This is by design. The story builder modifies the embedded URL to optimize the appearance of the survey in the story.
Solution or Workaround
  1. In ArcGIS StoryMaps, navigate to the story and add the Embed block. Refer to ArcGIS StoryMaps: Add embeds for instructions.
  2. In the Add web content window, embed the survey’s URL with an iframe code and add the ?hide&embed components to the survey's URL. An example of the edited URL with an iframe code is as follows:
<iframe src="https://survey123.arcgis.com/share/9d80d1a717444499aae1e640c71e4ecd?hide&embed&portalUrl=<machine_name>/portal"></iframe>
  1. Click Add in the window's lower-right corner to add the survey to the story.
The image below shows a survey embedded in a story using the iframe code.
Embedded survey with header, footer and theme
Article ID: 000028058
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 3
  • ArcGIS StoryMaps
  • ArcGIS Survey123
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
