Urban satellite imagery outputs an empty map display
While attempting an urban satellite imagery output, an empty map displays.
Cause
The zoom is not close enough to view the imagery area.
Solution or Workaround
The hashed lines on the full-extent map show the area where imagery raster data exists. Use the Zoom In tool until hashed lines no longer display, but imagery instead, then make the changes before outputing a map file.
