PROBLEM
Updates to referenced map image layers not reflected in the ArcGIS Enterprise portal
First Published: September 3, 2025
Last Published: September 3, 2025
When sharing a web map as a referenced map image layer from ArcGIS Pro, updates to the source data are not immediately visible in Map Viewer. Although the layer directly references the registered data source and is expected to reflect current changes, rendering or caching delays cause outdated or inaccurate display.
Cause
The map image layer is published using the Visualization configuration, which creates a cached image service optimized for fast display performance. The cache must be rebuilt and replaced to reflect edits to the source data. As a result, changes are not immediately visible and are only reflected after the cache is updated, causing a delay based on the cache update process.
Solution or Workaround
In ArcGIS Pro, publish the web map using the Reference registered data: Exploratory configuration in the Share As Web Map pane to dynamically reference the source data. This configuration ensures edits to the source data are immediately reflected in the service, as no data is cached for rendering. Refer to ArcGIS Pro: Share a web map using a chosen configuration for instructions.
The configuration options in the Share As Web Map pane
Article ID: 000037476
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
