PROBLEM
UNIX scripts for managing ArcIMS servers and services do not work after upgrade to 4.0 or 4.0.1
On UNIX ArcIMS services and servers can be managed using the command line. This is implemented using scripts. After upgrading from ArcIMS 3.x to 4.x, the scripts previously used no longer work correctly.
Cause
Two of the Java Archive (JAR) files used in the UNIX scripts for managing ArcIMS servers and services have changed names in ArcIMS 4.0 and 4.0.1.
Solution or Workaround
After upgrading, modify the scripts for use with ArcIMS 4.0 and 4.0.1.
  1. Open the script in a text editor.
  2. Find
    $JARHOME/arcims_sdk.jar
    and replace it with
    $JARHOME/esri_mo10.jar
  3. Find
    $JARHOME/arcims_ressdk.jar
    and replace with
    $JARHOME/esri_mo10res.jar
  4. Save and close the script.
Article ID:000005299
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
