PROBLEM
Unintentional inclusion in export presets created by ArcGIS Pro
First Published: August 24, 2023
Last Published: August 6, 2025
In ArcGIS Pro versions 2.9 through 3.1, PDF export presets include the passwords for opening and editing documents if the passwords are populated at the time the preset is created. If passwords are not populated when the preset is created, no further action is required.
Cause
The passwords are unintentionally written to the file.  However, these passwords are not applied when the preset is used for exporting.
Solution or Workaround
This defect is fixed in the ArcGIS Pro 3.1.3 and 3.0.6 patches. For earlier versions of ArcGIS Pro 3.1.x or 3.0.x releases, recreate the export preset after verifying there are no passwords set in the PDF security settings.
Article ID: 000031127
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
