PROBLEM
Uninstalling ArcGIS Maps for Office leads to resetting the ArcGIS connection URL
Last Published: September 11, 2023
Uninstalling ArcGIS Maps for Office does not completely revert the state of the software to its base form. Some issues occur because of this, such as problems resetting the ArcGIS connection URL.
ArcGIS Maps Configuration dialog box showing connection requires restart
Cause
This issue is caused by the ArcGIS Maps folder remaining in the Roaming directory after uninstallation.
Solution or Workaround
To cleanly uninstall ArcGIS Maps for Office, follow these steps:
  1. Uninstall ArcGIS Maps for Office from Control Panel. Click Start > Windows > Control Panel.
  2. Click Programs and Features.
  3. Navigate to the Roaming folder (found in %AppData%) and delete the ArcGIS Maps folder.
  4. Click Start > User > AppData > Roaming, and delete the ArcGIS Maps folder.
  5. Restart the machine. Ensure the ArcGIS Maps folder is no longer in C:/Program Files (x86).
  6. Reinstall ArcGIS Maps for Office on the machine, and configure as normal.
This method deletes all the related files from the previous install, hindering new workflows.
Article ID: 000020199
Software:
  • ArcGIS for Office 4 0
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
