PROBLEM
Unable to view reports in Esri Business Analyst Desktop when SSL is enabled in an ArcGIS Online organization
First Published: August 16, 2016
Reports do not display in Esri Business Analyst Desktop.
Cause
Esri Business Analyst Desktop reports are not displayed when an organization enables Secure Sockets Layer (SSL), because there is a higher security protocol on how services communicate. Therefore a secure connection to ArcGIS Online is required to enable programs such as Esri Business Analyst Desktop, ArcGIS for Desktop, and Business Analyst Web Apps to communicate with each other.
Solution or Workaround
Connect to a secure ArcGIS Online Organization by following the steps:
  1. Navigate to Start > All Programs > ArcGIS, and click ArcGIS Administrator.
  2. Select the machine name to specify the machine to be edited, and click Advanced.
    Image displays the options to select in ArcGIS Administrator.
  3. In the Advanced Configuration dialog box, click Manage Portal Connections.
  4. In the Manage Portal for ArcGIS Connections dialog box, click Add.
  5. In the Add Portal for ArcGIS dialog box, type https://www.arcgis.com, and click OK.
  6. Click the newly added URL, and click Connect.
    Image displays the steps to create a connection with the new URL.
  7. Click Save to apply the new settings.
  8. Open Business Analyst Desktop and login with ArcGIS Online credential to confirm the reports are now available.
Article ID: 000013857
Software:
  • More Products
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
