PROBLEM
Unable to view layers from a federated server in Portal for ArcGIS Map Viewer
First Published: May 18, 2018
Non-administrators are unable to view layers from a federated server in Portal for ArcGIS Map Viewer.
Cause
The layers do not have an item ID and therefore cannot be accessed by non-administrators of the organization. This can occur if the privatePortalURL property is left blank during federation of the server.
Solution or Workaround
Update the privatePortalURL property by following the steps below:
  1. Sign in to the ArcGIS Portal Directory with an administrator role.
  2. Click System > Properties > Update Properties.
  3. In the Update System Properties dialog box, insert the following code into the JSON with the URL of the load balancer:
   "privatePortalURL": "https://lbprivate.domain.com:7443/arcgis"
  1. Click Update Properties.
Article ID: 000018394
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
