PROBLEM
Unable to use the VBScript expressions in ArcMap
Last Published: October 19, 2021
In some instances, users are unable to use VBScript to create label expressions in ArcMap. The labelling of a feature class in a geodatabase cannot be completed using the Label Expression window. This problem persists even after performing an ArcGIS Desktop soft reset. Sometimes, ArcMap returns the error message Error: The expression contains an error. Modify the expression and try again.
Cause
Possible causes include:
  • The machine's antivirus software restricts the use of VBScript.
  • The machine runs on a 64-bit Windows operating system.
Solution or Workaround
Depending on the cause, use the workarounds below to resolve the issue.
Check and edit settings or reinstall antivirus software where applicable
The following workaround may require the assistance and permission of a system administrator. Consult a qualified computer systems professional if necessary.
Check and reinstall antivirus software where applicable to resolve the issue. Refer to Error: The expression contains an error. Modify the expression and try again for more information.
Run the script on a 32-bit operating system platform
VBScript does not run on 64-bit Windows operating systems. Refer to Problem: VBScript and JScript geoprocessing scripts do not run on a 64-bit Windows OS and ArcMap: 24046: Tool <value> cannot use VB expressions for services for more information.
Article ID: 000026316
Software:
  • ArcMap 10 6
  • ArcMap 10 7
  • ArcMap 10 8
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
