PROBLEM
The Smart Editor widget in ArcGIS Web AppBuilder fails to load shapefiles added from the Add Data widget.
This is expected behavior. The zipped shapefile added using the Add Data widget is not editable. The Smart Editor widget only works with editable layers, which must be set when editing the web app.
As a workaround, publish the shapefiles as hosted feature layers to ArcGIS Online, and recreate the web app.
Note: Ensure the published hosted feature layers are editable. Refer to ArcGIS Online: Manage settings for editing for instructions.
The image below shows the Smart Editor dialog box with the editable layers.
Article ID: 000022440
Get help from ArcGIS experts
Start chatting now
