PROBLEM
Unable to toggle the visibility of the map layers in the Map Layers widget in ArcGIS Experience Builder
Last Published: May 1, 2025
In ArcGIS Experience Builder, the Map Layers widget lists the available map layers and allows users to control the visibility on the map. However, in some instances, the option to toggle the visibility of the map layers is not available in the Map Layers widget when viewing the web experience.
Cause
  • The ‘Interact with a Map widget’ option is not selected.
  • The ‘Toggle layer visibility’ option is not enabled.
Solution or Workaround
Use one of the following workarounds to resolve the issue.
Select and enable the necessary options in the Map Layers widget
  1. In ArcGIS Experience Builder, depending on the template used, add the Map Layers widget from the Insert widget pane to the map if necessary.
The 'Insert widget' pane with the 'Map Layers' widget being selected in ArcGIS Experience Builder.
  1. In the Map Layers pane, on the Content tab, select the Interact with a Map widget option under Source.
  2. Click the drop-down arrow to select the map.
  3. Under Options, toggle on the Toggle layer visibility option. Toggle on the other options if needed.
The 'Interact with a Map widget' and 'Toggle layer visibility' options are being selected and enabled in the Map Layers pane.
  1. On the builder toolbar, click Save > Publish.
The Save and Publish buttons on the builder toolbar.
Use the Map widget
  1. In ArcGIS Experience Builder, depending on the template used, add the Map widget from the Insert widget pane to the map if necessary.
The 'Insert widget' pane with the Map widget being selected.
  1. In the Map pane, on the Content tab, click Select map under Source to add the data source.
The 'Select map' button being selected to add the data source in the Map pane.
  1. Navigate to Tools and toggle on the Layers option. Configure other settings if needed.
The Layers option being toggled on under the Tools section in the Map pane.
Article ID: 000028614
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
