PROBLEM
Unable to snap to new sketch's vertices when creating a new line or a polygon
When first creating a new line or a polygon, the ability to snap to the new sketch's vertices is not available when snapping has been set.
Cause
This is intended functionality because the sketch is not actually a feature until the sketch is finished.
Solution or Workaround
To snap to vertices or an edge in the sketch, check the option in the snapping menu to edit the sketch.
[O-Image] Sketch Snapping
    Article ID:000008684
    Software:
    • ArcMap 8 x
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
