PROBLEM
Unable to share locators in ArcGIS Pro
First Published: April 1, 2022
Last Published: October 21, 2025
In some instances, attempts to share locators using the Share Locator or Share As Locator option fail in ArcGIS Pro.
The image below shows the Share Locator option not available on the top ribbon in ArcGIS Pro.
The Share tab in ArcGIS Pro with the Share Location option not available.
The image below shows the Share As Locator option not available in the Catalog pane in ArcGIS Pro.
The Catalog pane in ArcGIS Pro with the Share As Location option not available.
Cause
  • An ArcGIS Online account is used to access ArcGIS Pro.
  • The portal connection is not added in ArcGIS Pro.
  • The user account has insufficient privileges.
Solution or Workaround
Use one of the methods below to resolve the issue.
Log in using the ArcGIS Enterprise account
Log in to ArcGIS Pro using the ArcGIS Enterprise account. Refer to ArcGIS Pro: Sign in to your organization for instructions and more information.
Add the portal connection in ArcGIS Pro
In ArcGIS Pro, add the portal connection to share the locator to the ArcGIS Enterprise portal. Refer to ArcGIS Pro: Manage portal connections from ArcGIS Pro for instructions and more information.
Change the member’s role to Publisher or Administrator
Change the member’s role to the default Publisher or Administrator to share the locator. Refer to Portal for ArcGIS: Manage members for more information.
The ability to share locators from ArcGIS Pro to ArcGIS Online using the Share Locator or Share As Locator option is yet to be available. ArcGIS Online uses only the World Geocoding Service as a locator. Alternatively, create a locator package using the Package Locator tool in ArcGIS Pro, and upload it to ArcGIS Online.
Article ID: 000027462
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
