PROBLEM
Unable to share location in ArcGIS Field Maps
First Published: May 18, 2022
Last Published: March 13, 2025
The location of mobile workers is tracked and recorded using ArcGIS Field Maps. Despite having ‘Location sharing’ enabled by the organization and the ArcGIS Tracker add-on license assigned, at times, the My Tracks map card toggle button is disabled and the message ‘Sharing is Unavailable’ is displayed upon launching ArcGIS Field Maps, as shown in the image below.
The Sharing is Unavailable message is displayed on ArcGIS Field Maps.
Cause
  • The member’s default role has insufficient privileges to share the location.
  • ‘View location tracks’ is disabled.
  • ‘View content shared with organization’ is disabled.
Solution or Workaround
Change the role of the user with the privilege to share the location
Only default administrators and custom roles with administrator privileges can perform the following workflow.
In ArcGIS Online, change the user’s role to User, Publisher, or Administrator. Refer to ArcGIS Online: Roles and ArcGIS Online: Change member roles for further instructions.
Enable 'View location tracks' for the member's custom role
  1. Log in to ArcGIS Online and click Organization > Settings.
  2. Click Member roles on the left of the page.
  3. Browse to the custom role, click More options and select Edit.
  4. In the Edit role window, under Role privileges, expand General privileges > Content, and toggle View location tracks on.
The 'View location tracks' toggle.
  1. Click Save.
Enable ‘View content shared with organization’ for the member’s custom role
  4. In the Edit role window, under Role privileges, expand General privileges > Content, and toggle View content shared with the organization on.
The 'View content shared with organization' toggle.
  1. Click Save.
The message 'Location Sharing Off' is displayed and location sharing can now be enabled in ArcGIS Field Maps.
The message 'Location Sharing Off' is displayed on ArcGIS Field Maps.
The Location sharing toggled.
Article ID: 000027701
Software:
  • ArcGIS Online
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
