PROBLEM
Unable to share GPX files in ArcGIS Enterprise portal
First Published: April 13, 2026
Last Published: July 20, 2026
In the ArcGIS Enterprise portal, sharing a GPX file uploaded through ArcGIS REST API returns the following error message:
Error:
Failed to update sharing.
The error returned in ArcGIS Enterprise 12.0
When the GPX file is shared using the ArcGIS Portal Directory, the following error message is returned:
Error:
This type of item cannot be shared.
Error: 400
The error message returned when an item is shared publicly using the ArcGIS Portal Directory
Cause
A GPX file is not a supported shareable item type in the ArcGIS Enterprise portal. As a result, although the file can be uploaded through ArcGIS REST API, the portal prevents the item from being shared.
Solution or Workaround
Convert GPX data to features in ArcGIS Pro and share the feature layer with the organization
  1. Convert GPX data to features in ArcGIS Pro.
    1. Open the ArcGIS Pro project and click Project > Portals.
    2. Log in and set as the active portal.
    3. Click the back Icon for back button icon.
    4. Repeat Steps 2 through 4 in FAQ: Can GPX files be opened in ArcGIS Pro? In this example, Output Feature class is specified as Test_GPX_Out, and for Output Type, Points is selected.
The GPX To Features pane with its configured parameters
  1. Share the feature layer to the ArcGIS Enterprise portal. In this example, Name is specified as Test_GPX, and for Sharing Level, Organization is selected.
The Share As Web Layer pane showing the configured item name and sharing level
  1. Ensure the sharing level is retained in ArcGIS Online.
    1. Sign in to ArcGIS Online and navigate to Content > My content.
    2. On the My content tab, select the hosted feature layer to open the item page.
    3. On the item page, navigate to Sharing.
The item is successfully shared with the organization.
Article ID: 000040980
Software:
  • ArcGIS REST API
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
