PROBLEM
Unable to select licenses when creating a new Portal for ArcGIS license file in My Esri
First Published: September 25, 2025
Last Published: September 25, 2025
When generating a new Portal for ArcGIS license file in My Esri, certain license options are disabled and cannot be selected. This prevents administrators from allocating all available licenses to the portal environment.
Cause
This issue occurs because the licenses are already allocated to an existing license file. When creating a new license file, My Esri does not allow those licenses to be reused, so they remain disabled.
Solution or Workaround
The following workflow requires specific My Esri privileges. If the options are not visible, request the necessary permissions from the organization’s My Esri administrator.
To resolve the issue, edit the existing license file in My Esri to transfer the current user types and license allocations into a new file. This action cancels the current file and replaces it with the updated one, reusing the existing licenses. Refer to How To: Edit license files in My Esri for Portal for ArcGIS 10.7 and later versions for instructions.
Article ID: 000037841
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
