PROBLEM
Unable to select features from a DBTheme in ArcView
When viewing SDE layers in ArcView, features cannot be selected.
Cause
A possible cause is the shared_pool_size parameter in the Oracle configuration file is set too small.
Solution or Workaround
  1. Open the initorcl.ora file located in the <Oracle install directory>/database/ folder in a text editor.
  2. Scroll down to the following portion of the file.
    shared_pool_size = 3500000 # INITIAL
    # shared_pool_size = 3500000 # SMALL
    # shared_pool_size = 5000000 # MEDIUM
    # shared_pool_size = 9000000 # LARGE
  3. Change the shared_pool_size value to either 5000000 or 9000000. It should now look like. . .
    shared_pool_size = 9000000 # INITIAL
  4. Save the file and close the text editor.
Article ID:000005211
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
