PROBLEM
Unable to search for features in a map in ArcGIS Field Maps
Last Published: October 27, 2022
When searching for features in ArcGIS Field Maps using the Search function, the features are not displayed in the search result, as shown in the image below.
The feature 'Greenshaw' is not displayed in the suggestions section.
Cause
  • The 'By Layer' search setting is not enabled and configured.
  • The search setting is set to 'Equals'.
Solution or Workaround
Depending on the cause, use one of the following workarounds to resolve the issue.
Enable and configure the ‘By Layer’ search setting in ArcGIS Online
Enable By Layer and configure the feature search for maps in ArcGIS Online. Refer to ArcGIS Online: Configure feature and table search for maps for further instructions.
Change 'Equals' to 'Contains' for the search term in ArcGIS Online
Configure the search result to contain the search term by following the instructions below.
  1. Log in to ArcGIS Online and click Content > My Content.
  2. Browse to and click the web map.
  3. On the item details page, click the Settings tab.
  4. Scroll down to the Web Map section, under Application Settings, select Contains from the drop-down menu.
  5. Click Save.
The configuration of the search under Application Settings.
In ArcGIS Field Maps, tap Enter after typing the feature name in the Search function for the feature to be displayed in the suggestion section, as only results from the ArcGIS World Geocoding Service are displayed when typing.
The feature found through the Search function is displayed in the suggestions section.
The feature 'Greenshaw' is displayed in the suggestions section.
Article ID: 000028521
Software:
  • ArcGIS Online
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
