PROBLEM
Unable to save shapefiles with date fields in ArcGIS Pro
Last Published: September 30, 2021
In some instances, attempts to save newly created date fields in a shapefile in ArcGIS Pro fail, and return the following error message:
Error:
ERROR 000664: Invalid Input: The type of dataset is not supported.
The edited date fields are unable to be saved and returns the error message.
Cause
This is a known limitation. More than one date field is not supported for a shapefile in ArcGIS Pro version 2.7 and earlier.
Solution or Workaround
Choose one of the methods below to resolve the issue.
Convert the shapefile to a geodatabase feature class
Use the Feature Class To Feature Class (Conversion) geoprocessing tool to convert the shapefile to a feature class. Refer to ArcGIS Pro: Feature Class To Feature Class (Conversion) for more information.
Use the latest version of ArcGIS Pro
Update ArcGIS Pro to the latest version. Refer to ArcGIS Pro: Update ArcGIS Pro or ArcGIS Pro: Install ArcGIS Pro for steps to do so.
Article ID: 000025098
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
