PROBLEM
Unable to save large Schematic diagrams in SDE
Unable to save a large diagram layout in SDE.
Cause
This is a problem with the 'maxblobsize' and/or the 'blobmem' parameters in the SDE configuration.
Solution or Workaround
Change the 'maxblobsize' and 'blobmem' settings in SDE.
To figure out the setting, the best thing to do is create the 'normal’ type of diagram and apply an algorithm, such as the Hierarchical - Smart Tree. Save and close the diagram. Re-open and verify that the layout was saved.
If it did not save, then the parameters need to be increased. There is no method for figuring out the size without testing it due to many factors, such as the number of labels and subtypes, that influence the final storage size.
  1. Run the following command as the SDE administrator. Change the 'sde' entries to match the correct user name and password, and also set the maxblobsize and blobmem parameters accordingly:
    Code:
    sdeconfig -o alter -u sde -p sde -N -q -v maxblobsize=4000000
    Run the same command, but alter the blobmem parameter.
Article ID:000008039
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
