PROBLEM
Unable to save form changes in ArcGIS Field Maps Designer
Last Published: May 14, 2024
When saving a form in ArcGIS Field Maps Designer, the process fails, and the following error messages are returned:
Error:
Unable to save your form changes. Check the layer settings and confirm that you have the privileges required to make changes.
An error message in ArcGIS Field Maps Designer.
Error:
Unable to save your form changes. The form contains invalid properties or an error has occurred.
Cause
  • The field name of the form element uses a reserved SQL keyword.
  • Certain form elements have invalid properties.
  • The hosted feature layer used in the web map is corrupted.
Solution or Workaround
Depending on the cause, use one of the following solutions.
Change the field name of the form element
In the Properties pane of the form element, in the Field name parameter, remove the previous field name and replace it with a new one not included in the list of reserved SQL keywords. Refer to Microsoft Build: Reserved Keywords (Transact-SQL) for more information.
Remove and re-add the form element
  1. In the ArcGIS Field Maps Designer form, remove the form element by clicking Delete The Delete button in ArcGIS Field Maps Designer..
  2. Re-add the form element to the form. Refer to ArcGIS Field Maps: Add basic form elements for more information.
Republish the web map
Delete and republish the web map using the same hosted feature layer used in ArcGIS Online. Refer to ArcGIS Online: Save maps (Map Viewer) for further instructions.
Article ID: 000032441
Software:
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
