PROBLEM
The Symbol Selector dialog boxes show a palette of symbols that reside in any of the currently referenced styles or in a user's personal styles. Using the Symbol Selector, users can implement custom symbols if none of the symbols desired are present in the palette or are difficult to find.
However, users are unable to save customized symbols in the Symbol Selector if the Save As button in the Symbol Selector dialog box is disabled.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL24-0EM39000000wdbO.png)
The button may be disabled due to the following reasons:
Depending on the cause, the following workarounds are applicable.
Note: Close all Esri applications running on the system before proceeding to the workaround.
Ensure there is Read and Write access to the .style file
This file is located at:
C:\Users\*username*\AppData\Roaming\ESRI\Desktop10.x\ArcMap
Note: Enable 'Show Hidden Files and Folders' if unable to locate the application data folder. This can be done in Windows 7 or 8 by clicking Organize Drop-down > Folder and Search Options > View Tab > Show Hidden Files and Folders.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL2C-0EM39000000wdbR.png)
Rename the Normal.mxt file
C:\User\*username*\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Templates
Warning: The instructions below include making changes to essential parts of the operating system. Esri recommends performing a back up of the operating system and files, including the registry, before proceeding. Consult a qualified computer systems professional if necessary. Be aware that renaming the Esri folders is a factory reset of ArcGIS, and therefore all third party tools, custom scripts, or custom toolbars currently installed must be reinstalled accordingly. Additionally, all existing folder connections must be reconnected. Esri cannot guarantee results from incorrect modifications while following these instructions. Proceed with caution.
Note: If ArcGIS Pro is installed on the machine, ensure that an ArcGIS Pro license is not checked out from ArcGIS Online. If unsure that the ArcGIS Pro license is checked out on the machine, contact Esri Technical Support at 888-377-4575.
Rename the Esri folder
Edit the Registry Key
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012396/00N39000003LL2C-0EM39000000wdbS.png)
Article ID: 000012396
Get help from ArcGIS experts
Start chatting now
