PROBLEM
Unable to save changes on the Settings tab in ArcGIS Hub
Last Published: July 15, 2020
The Save button is unavailable when attempting to save the changes made on the Settings tab.
The following image shows the disabled Save button on the Settings tab in ArcGIS Hub.
Image of the Save button disabled
Cause
The following are possible causes:
  • The Summary text box is empty.
  • Administrative privileges are not enabled for the team member.
Solution or Workaround
Use one of the methods below to resolve depending on the cause.
Fill in the Summary text box
  1. In the ArcGIS Hub site, navigate to the Settings tab.
Image of the Settings tab
  1. On the Settings tab, fill in the text box in the Summary section.
Image showing the Summary text box is filled
  1. Click Save to save the changes.
Assign administrative privileges to the team member
To save the changes made in the ArcGIS Hub settings, assign appropriate privileges to team members for full editing access to the site. Refer to ArcGIS Hub: Core team member for more information.
Article ID: 000023492
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
