PROBLEM
The Portal for ArcGIS health check is used to determine if all the available portal machines are able to receive and process requests. The portal health check can be accessed using the following URLs:
https://Portalmachine.com:7443/arcgis/portaladmin/healthCheck
https://WebAdaptorMachine.com/webadaptor/portaladmin/healthCheck
Note: The URL is case-sensitive. Ensure 'healthCheck' is correctly appended to the Enterprise URLs to avoid receiving Error 404 messages.
In some instances, running the health check via ArcGIS Web Adaptor after upgrading to Portal for ArcGIS 10.8.1 returns the following error message:
Error: Could not access any Portal machines. Please contact your system administrator.
This is a known issue related to BUG-000136092 in ArcGIS Web Adaptor (IIS) 10.8.1 where network requests fail, and ArcGIS Enterprise becomes unresponsive.
Article ID: 000026032
Get help from ArcGIS experts
Start chatting now
