PROBLEM
Unable to return an offline ArcGIS Pro Named User License
First Published: October 26, 2016
Last Published: June 24, 2026
When attempting to return an offline ArcGIS Pro portal license, the Authorize ArcGIS Pro to work offline option is checked and disabled. This setting enables an ArcGIS Online organization account to work in ArcGIS Pro offline.
The Authorize ArcGIS Pro to work offline option is checked and greyed out in the ArcGIS Pro Portals tab
Cause
The user is not signed in to the licensing portal. ArcGIS Pro is unable to indicate which portal to return the license since the user does not need to be signed in to any portal or have internet access when using ArcGIS Pro offline. Refer to ArcGIS Pro: Sign in to your organization for more information.
To determine if the user is logged in to the correct portal, navigate to the Project > Portals tab in ArcGIS Pro.
The correct ArcGIS Pro organization account to return the license to in the Portals tab
The license can be checked back in if the licensing portal (key icon) is the same as the active portal (check mark icon).
Solution or Workaround
Use the following steps to log in to the licensing portal and obtain a license for online use.
  1. Open ArcGIS Pro, and click Projects > Portals. Find the portal connection containing the key on the icon; this is the licensing portal.
  2. Sign in to the portal. Right-click the desired account and click Sign in.
The Sign in button to sign in to the licensing portal in the Portals tab
  1. Click the Licensing tab, and uncheck the Authorize ArcGIS Pro to work offline option.
  2. Sign in to ArcGIS Pro again. The license is now returned for online use.
Article ID: 000014443
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
