PROBLEM
In ArcMap, users can install add-in files via the Add-In Manager. In the Add-In Manager dialog window, the Options tab allows users to provide a list of additional well-known folder locations, which are additional shared locations that can be used by one or more users to copy and delete add-ins to and from ArcMap. These shared well-known folder locations can also be removed from this list in the Options tab.
In some instances, when one of these well-known folder location paths is selected in the Options dialog window, the Remove Folder is disabled, and the selected path cannot be removed.![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012043/00N39000003LL24-0EM39000000wdUG.png)
The Remove Folder button is disabled if the folder that the path refers to has been renamed, moved, or deleted.
Article ID: 000012043
Get help from ArcGIS experts
Start chatting now
