PROBLEM
Unable to register tables with a geodatabase
Users are unable to register a table in a feature class with a geodatabase.
Cause
This occurs when the table has multiple incrementing columns including an ObjectID column.
The ObjectID column, which is an incrementing column, is already created by ArcGIS when a feature class is registered in a geodatabase. A geodatabase requires the ObjectID field to be the incrementing field to allow the table to be registered.
The existence of multiple incrementing columns requires customization, as the delta tables must be synchronized.
Solution or Workaround
Select the ObjectID column to allow the table to be registered with a geodatabase. For more information, refer to the following ArcGIS Help documentation, Workflow: Creating tables with SQL and registering them with the geodatabase.
    Article ID: 000012556
    Software:
    • Legacy Products
    • ArcMap
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
