PROBLEM
In some instances, when attempting to register a new spatiotemporal big data store with ArcGIS Server, the process fails and returns the following error message:
Error: Machine https://<datastore_machine>.<domain>.<top-level_domain>:<port_number>/arcgis/datastoreadmin> returned an error. Attempt to configure data store failed. Caused by: Failed to configure spatiotemporal big data store. Caused by: Attempt to create ArcGIS Data Store configuration store failed. Caused by: <HTTP PUT request endpoint> failed. Code 401. Error: Unauthorized
The leftover files from a previous data store configuration do not match with the current installation, such as those from a relational or tile cache data store. The current installation for the spatiotemporal big data store reuses the same folder because it has the same name, which resulted in the error.
C:\
Article ID: 000033200
Get help from ArcGIS experts
Start chatting now
