PROBLEM
Unable to reconcile and post when archiving is enabled
Reconciling and posting a geodatabase version may fail if there are one or more archived feature classes. In this case, the index of the archived feature class may need to be rebuilt.
Cause
The spatial index of the archived feature class is not in synch with the index of the edited feature class.
Solution or Workaround
The spatial index of the archived feature class can be recalculated using the sdelayer -o alter command.
  1. Check the spatial index of the edited feature class (named 'states' in this example) with the sdelayer -o describe_long command.
    [O-Image]
  2. Check the spatial index of the archived feature class ('states_H') with the sdelayer -o describe_long command.
    [O-Image]
  3. Recalculate the spatial index of archived feature class to match the spatial index of the edited feature class using the sdelayer -o alter command.
    Code:
    C:\>sdelayer -o alter -l states_H,shape -u wilson -p wilson -i 5151 -g 20,0,0,FULL
    ArcSDE 10.0 for Oracle11g Build 1937 Tue Aug 16 16:08:18 2011
    Layer Administration Utility
    Change spatial index from SPIDX_GRID,14,FULL
    to SPIDX_GRID,20,FULL
    Are you sure? (Y/N): y
    Successfully Modified the Layer
    Successfully changed spatial index parameters and rebuilt as needed
Article ID:000011481
Software:
  • Legacy Products
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
