PROBLEM
Unable to publish web services from ArcGIS Pro to Portal for ArcGIS with the ArcGIS Web Adaptor 11.1 Reliability Update 2 Patch installed
Last Published: December 14, 2023
When publishing web services from ArcGIS Pro to Portal for ArcGIS with the ArcGIS Web Adaptor (IIS) 11.1 Reliability Update 2 Patch installed, the process fails.
Cause
The domain name and IP address of the local machine have been edited or removed from the hosts file on the virtual machine.
Solution or Workaround
Warning:
The instructions below may change part of the machine's operating system. Contact the organization's IT department for assistance, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions.
The following steps require the local machine's IP address and domain name. Contact the organization's IT department for assistance, if necessary.
  1. On the virtual machine, create a new folder.
  2. In File Explorer, navigate to the hosts file, which by default is:
C:\Windows\System32\drivers\etc
  1. Right-click the hosts file and open the hosts file in a text editor, for example, Notepad.
  2. In the text editor, add a new line at the end of the file and type in the local machine's IP address and domain name without the hashtag.
The IP address and Domain name added to the hosts file
  1. Save the hosts file and close the text editor.
Article ID: 000031621
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 1
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
