PROBLEM
Unable to overwrite a sync-enabled hosted feature layer in ArcGIS Pro
Last Published: September 20, 2024
In ArcGIS Pro, it is possible to overwrite an ArcGIS Online sync-enabled hosted feature layer and have it still be sync-enabled after the overwrite. However, there are instances when the sync-enabled hosted feature layer cannot be overwritten.
Cause
The hosted feature layer contains replicas after offline areas are created in the ArcGIS Field Maps mobile app, ArcGIS Field Maps Designer, or ArcGIS Online. This behavior is similar to the documented error, 001989: Service cannot be overwritten if Sync is enabled and replicas exist.
Solution or Workaround
Use one of the following methods to remove offline areas so that a sync-enabled hosted feature layer can be overwritten.
Remove the offline areas in the ArcGIS Field Maps Designer web app
Refer to ArcGIS Field Maps: Delete a map for instructions to delete offline areas.
Remove the offline areas in the ArcGIS Field Maps mobile app
  1. Log in to the ArcGIS Field Maps mobile app via ArcGIS Online and open the project.
  2. Navigate to the offline area, tap the Overflow menu Overflow menu icon, and tap Remove Area for the offline map areas.
Remove the offline areas using ArcGIS API for Python
Use ArcGIS Notebooks to run the Python script.
  1. Import the necessary modules.
from arcgis.gis import GIS
from arcgis.mapping import WebMap
gis = GIS('home')
  1. Replace <MAP_ITEM_ID> with the item ID of the web map that requires offline areas to be deleted.
offline_map_item_id = '<MAP_ITEM_ID>'
offline_map_item = gis.content.get(offline_map_item_id)
offline_map = WebMap(offline_map_item)
  1. Define the function to remove the offline areas of the map.
for ids in offline_map.offline_areas.list():
    print('Removing map area: ' + ids.title)
    ids.delete()
The code block below demonstrates the full script.
gis = GIS('home')
offline_map_item_id = '694b23c51eca4d7c8245b98ac13165e8'
    ids.delete()
  1. Select the cell with the expression and click Run Run icon.jpg on the top ribbon.
Article ID: 000031917
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
