PROBLEM
Unable to open an MXD project in ArcMap
First Published: April 16, 2021
Last Published: April 16, 2021
The MXD project fails to open in ArcMap, and a layer has a red exclamation point next to the layer name in the Table Of Contents. The check box beside the layer is not available. In some instances, the following error message may be returned:
Error:
Classfactory cannot supply requested class.
The Table Of Contents displaying a layer with a broken data link
Cause
The MXD project contains layers with broken data links. ArcMap searches for the data referenced by each of the layers when launching the MXD project. A broken link occurs when the data source for a layer is unavailable, and the layer is not drawn. This may be due to the MXD project that is saved in an organizations' ArcGIS Server, but the ArcGIS Server is either no longer available or disconnected, returning the error stated above.
Solution or Workaround
The following procedure does not fix the broken links. However, the procedure allows opening the MXD project without returning any error.
Follow these steps to remove the broken layers:
  1. Disconnect the internet connection and open the MXD project.
  2. In the Table Of Contents, right-click the layers that have an exclamation mark and click Remove.
The Table Of Contents displays removal of the broken data link layer
  1. Save the MXD project and close ArcMap.
  2. Reconnect the internet connection and open the MXD project.
Article ID: 000025045
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
