PROBLEM
Unable to move or select annotation in ArcGIS Pro
First Published: January 26, 2021
Last Published: January 26, 2021
In ArcGIS Pro, when attempting to move or select annotation using the Select, Annotation, or Move tool in the map or layout view, the annotation is non-selectable or non-editable.
Cause
The following are known causes for this issue:
  • The editing capabilities of the annotation feature class is not enabled in ArcGIS Pro.
  • The annotation feature class is non-editable in ArcGIS Pro.
  • The labels of the layer are not converted to annotation.
  • The ‘Create a new selection’ option of the Select tool is not selected.
  • The display cache on the machine is not cleared.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Enable editing of the annotation feature class
In ArcGIS Pro, in the Contents pane, on the List By Editing tab, check the layer to enable editing. Refer to ArcGIS Pro: Specify which layers can be edited for more information.
Image of the Contents pane
Convert the non-editable annotation feature class to a geodatabase feature class
  1. In the Contents pane, browse to and right-click the layer.
  2. Click Data > Export Features.
  3. In the Export Features window, on the Parameters tab, click the drop-down arrow, and select the non-editable layer for Input Features.
  4. For Output Location, select a geodatabase as the location of the output feature class.
  5. Specify a name for Output Name, and click OK.
Image of the Export Features window
Ensure the labels are converted to annotation to be editable
Convert labels to annotation to edit or move them using the Annotation tool. Refer to ArcGIS Pro: Convert labels to annotation for more information.
Ensure the Create a new selection option of the Select tool is selected
Configure the Selection settings to select the Create a new selection option.
  1. Open the ArcGIS Pro project.
  2. On the top ribbon, click the Edit tab, and click Selection Options in the Selection group.
  3. In the Options window, on the Selection tab, under Selection combination mode, select the Create a new selection option. Click OK.
Image of the Options window
Clear the display cache on the machine
  1. Launch ArcGIS Pro. Click Settings on the bottom-left corner, and click Options.
  2. In the Options window, click the Display tab.
  3. Under Local cache, check the Clear cache check box, and click OK.
  1. Close and relaunch ArcGIS Pro.
The image below shows the annotation is selectable and editable using the Annotation tool in ArcGIS Pro.
Image of the editable annotation using the Annotation tool
Article ID: 000024987
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
