PROBLEM
Using Macromedia ColdFusion MX with Microsoft IIS and ArcIMS, problems result from the default installation of ColdFusion MX. Users may be unable to log into Administrator even though all services are running. ColdFusion-generated error messages appear in the ArcIMS Diagnostics test results.At ArcIMS 9.0, users may also see ERR0402. At ArcIMS 4.x, users may see the "URL ... is invalid" message.
ColdFusion MX installs a JRUN servlet ISAPI filter for IIS by default. If this filter is installed on the machine and made the default, the ArcIMS servlet connector may not function. This is the case if the ArcIMS servlet connector is installed within another servlet engine such as ServletExec or Tomcat on the same machine.
Article ID:000006338
Get help from ArcGIS experts
Download the Esri Support App
