PROBLEM
Unable to log in to ArcGIS Pro with a Personal Use subscription
Last Published: August 5, 2025
Starting July 22, 2021, changes were made to ArcGIS Personal Use subscriptions that require users to update their ArcGIS Online details.
Cause
Solution or Workaround
To continue using ArcGIS Pro as part of an ArcGIS Pro Personal Use subscription, follow the steps below.
  1. Log in to ArcGIS Online.
    • Use the same credentials used to log in to ArcGIS Pro.
  2. Once logged in, follow the prompts to Update user type, as shown in the following image:
  1. Once updated, log in to ArcGIS Pro.
If the issue persists, follow the steps below:
  2. Select Organisation.
  3. Select Licenses.
  4. Select Manage next to any expired licenses and remove by toggling off, and close the pop-up window.
  5. Select Members in the top tab.
  6. In the same row as your username click the options ellipsis (More options), and click Manage User Type.
  7. Select the box under User Type.
  8. Select GIS Professional Advanced.
  9. Select Save.
You should now be able to use ArcGIS Pro.
Article ID: 000026122
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
