PROBLEM
Unable to log in to ArcGIS Collector using an ArcGIS Online organizational account
Last Published: March 30, 2021
By default, an ArcGIS Online organizational account is required to log in to ArcGIS Collector on a device. In some instances, attempts to log in to ArcGIS Collector fail, despite using an ArcGIS Online organizational account.
Cause
The following are possible causes for the issue:
  • An ArcGIS Online public account is used to access ArcGIS Collector.
  • The ArcGIS Online organization is not activated.
  • The ArcGIS Online organization is activated, but the user account is not a member of the organization.
Solution or Workaround
Depending on the cause, use one of the following workarounds to resolve the problem.
Use an ArcGIS organizational account with a license for ArcGIS Collector to log in to the app
ArcGIS Collector does not support an ArcGIS Online public account for login and access. Refer to ArcGIS Collector: ArcGIS account requirements for more information on supported user types in Collector.
Ensure the ArcGIS Online organization is activated
  1. Log in to ArcGIS Online using the related organizational account.
  2. Ensure the Organization tab is visible on the Home page, as shown in the image below.
Image showing the Organization tab on the Home page of an ArcGIS Online organization
If the Organization tab is not visible, follow the workflow below to activate the ArcGIS Online organization.
  1. Complete the account activation process, and set up the organization. Refer to ArcGIS Online: Activate subscription for the steps to complete this.
  2. In ArcGIS Collector, log in using the ArcGIS Online organizational account created in Step 3.
Add the ArcGIS Online user account to the ArcGIS Online organization
Contact the ArcGIS Online organizational administrator to add a user account as a member of the organization to log in to ArcGIS Collector. Refer to ArcGIS Online: Join with an ArcGIS account created for you for more information.
Article ID: 000024512
Software:
  • ArcGIS Collector
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
