PROBLEM
Unable to load cache status in ArcGIS Server Manager
First Published: June 13, 2024
Last Published: June 13, 2024
In ArcGIS Server Manager, the cache completion status for map or image services fails to load. The Cache Status tab in ArcGIS Server Manager does not display the cache status progress, such as the completion percentage and number of tiles for each scale level.
Cause
  • The map or image services have stopped. The cache status cannot be accessed when the services are not running.
  • The cache for the map or image services are corrupted, or the cache folder is missing.
Solution or Workaround
Start or restart services
If the map or image services are not running, start the services. Refer to ArcGIS Server: Start a service in Manager for instructions. If the services are running, restart the services. Restarting services can resolve temporary issues that prevent the cache status from loading.
Rebuild the cache or the cache status
If the cache services are corrupted or the cache folder is missing, rebuild the cache using the Manage Map Server Cache Tiles (Server) tool. This tool creates and updates tiles in an existing web tile layer cache in ArcGIS Enterprise or ArcGIS Online, map image layers in ArcGIS Enterprise, and cached map or image services on a stand-alone server.
Alternatively, rebuild the map or image cache status using the Manage Map Server Cache Status (Server) tool. This tool is useful in rebuilding the cache status after manually copying tiles into the cache directory or building tiles on demand.
Article ID: 000032672
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
