PROBLEM
Unable to launch ModelBuilder after an ArcGIS Desktop upgrade
Last Published: October 6, 2021
In some instances, after an ArcGIS Desktop upgrade, ModelBuilder fails to launch in ArcMap.
Cause
This issue occurs when ArcGIS Desktop modules are corrupted during the upgrade process, causing the application to crash.
Solution or Workaround
To resolve the issue, run the ArcGIS Desktop repair wizard to repair the software.
  1. On the machine, navigate to Control Panel.
  2. Navigate to Programs and click Uninstall a program.
  3. Select ArcGIS Desktop <version number> and click Uninstall/Change to open the software's setup window. If prompted, click Yes.
  4. Select Repair and click Next.
The ArcGIS Desktop setup page showing the repair option
  1. Click Finish.
  2. Open ArcMap and launch ModelBuilder.
Article ID: 000025539
Software:
  • ArcMap 10 6
  • ArcMap 10 7
  • ArcMap 10 8
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
